So, here it is on the day I got it back in July (note the chrome bulldogs on the sidecovers! Why one earth would anyone do this?! I'm keeping them on there though
After some elbow grease:
The motor was completely frozen when I obtained the bike. Filled the cylinders up with silicone lubricant, let it sit for about 20 minutes, and with a wrench on the flywheel very easily broke it free. Pulled the engine out, and ripped the head and cylinders off to see the damage. Not too bad of a seize, and I probably could have run it, but I always say if anything's worth doing it's worth doing right, so I had the cylinders bored out to second over (.50)
The rest of the motor looked as you'd expect. The valves weren't the worst I'd seen, but were in definite need of some love and care
Shined them up and then lapped them
As the project currently sits, I'm just trying to get it running so I can ride it around next year. Next winter I plan on completely disassembling the thing and getting it back up to 100%. Unfortunately, the CA95 has to share project time with a '66 CB160 cafe racer that I'm converting over to use a monoshock from an R6 currently.
So, it will be slow going but I'll be on here frequently whenever I get the chance, and this site has already been a big help with some engine work I've had to do so thank you all for that!
The last thing I did to the bike was attempt to get the cam chain and cam sprocket on without removing the flywheel and stator. I don't think this is going to happen. I got frustrated and gave up haha.
And to end this long introduction, I got a never issued Kansas tag for it. Even came with the registration info for the tag!!
