Usually in the picture below the main fuel line from the pump (which has the protective spring around it) goes straight to the fuel input on the right side of the carb. But here for this CA model ZX-7R it has another smaller fuel input nipple on the left and you can see that I just put a fuel line to a T adapter to take care of it.
The clear lines are hose that is approved for oil and fuel use (although not high pressure). I used it for the vent line as I ran short of black fuel line and that stuff is a lot more expensive anyhow.
