Unread 04-23-2015, 06:51 PM
NickyRudolph NickyRudolph is offline
Default Honda ca95 clutch
Replacing the plates on my honda today. It had 5 plates all of the same thickness, so I doubled up on one at the start. Will this be a problem? Also, when putting on that plate with the springs behind it, do I tighten all the way down? How far do i go down. The tighter i go, the more impossible it gets to pull the clutch. Thanks.
Unread 04-28-2015, 06:17 PM
VegeKev VegeKev is offline
Hey Nick,
Those four bolts (6mm x 20mm) need to be tensioned to 4-5 ftlb
Kev.
