Unread 05-23-2013, 08:06 PM
VegeKev VegeKev is offline
Default Front Turn Signals
Hey,
Just a heads up for you State side people looking for a set of genuine turn signals....
http://www.ebay.com.au/itm/111076390...84.m1436.l2649
Freights a bit expensive for Oz....but should be OK if your on the other side of the planet
Cheers,
Kev.
Unread 05-24-2013, 08:25 AM
Thanks for the heads up! What's screwy is that the US CA95's did not have them at the time. Our handlebars have to be drilled and then find the handlebar switch. That's why I build my own signals.
Unread 05-24-2013, 12:40 PM
Yeah, from what I've read, the US Dept of Transportation had a regulation in place that specified a minimum distance between the left/right signals, and these early Hondas didn't comply. There was no regulation that required the signals, so the US Hondas didn't get them.
Since I had to replace my handlebars anyway, I bought Thailand-source bars, which were pre-drilled for the signals.
Unread 06-20-2013, 03:31 PM
Just another heads up if someone is looking for the Right Hand switch that has the turn signal switch.....
http://www.ebay.com/itm/HONDA-CB72-C...#ht_266wt_1172
Cheers,
Kev.
Unread 06-22-2013, 06:07 AM
Buckets81's Avatar
I was just about to bid on that but then I looked closer and saw that it was the left hand dimmer and horn switch. Oh well.
Cheers,
Kev.
Unread 07-16-2013, 03:03 PM
Hey,
Apologies...I should have looked closer
Here's a link to one that has been recently listed;
http://www.ebay.com/itm/HONDA-CA160-...14e7db&vxp=mtr
Cheers,
Kev.
Unread 07-17-2013, 02:18 AM
Hey,
Cheers,
Kev.
One needs to be careful when buying these as the seller will tell you that they fit several models when in fact they don't.
One fits over the internal spiral twist grip, where as the other fits the remote drum type twist grip more comonley used on the sports models.
Unread 07-17-2013, 02:56 AM
I got my right hand switch from Phil Denton Engineering in England, who made this spot-on aluminum replica. It still wasn't cheap ... $110.66 (£66.84), including shipping. Denton used to show the part on the web site, but now I don't see it. Perhaps it's still offered. It was listed as part code 35250212000. That price was quoted in October, 2011, when I purchased the part.
Unread 07-17-2013, 03:11 PM
I actually chased Denton Engineering a couple of months ago, asking if they still supplied these switches.....didn't even get a response
Unread 09-17-2013, 03:21 PM
Here's a new link to someone selling the RH blinker switch....and they have 4 for sale...
http://www.ebay.com/itm/231036063910...84.m1438.l2649
Kev.
