Unread 07-05-2012, 04:26 AM
1911tex 1911tex is offline
Default Spark Plug >>>
My CA95 currently has a NGK D6HA; others on here suggest D8HA; the shop manual suggests C10H............................what do ya'll suggest?
Unread 07-05-2012, 05:11 AM
Puzzleparadise's Avatar
D8HA is the correct one...here's the full scoop:
http://www.fourwheelforum.com/showth...ighlight=Spark
Unread 07-06-2012, 07:36 AM
With NGK spark plugs the lower the number the hotter the heat range . D8HA is the replacement spark plug . If the air/fuel ratio is a little rich or the motor is using a little oil (past the rings or valve guides ) a hotter heat range plug may be suitable . D6HA's fit but may be too hot and not color the porcelin a light tan /brown. If you've run the engine and the plugs are white you need the change plugs to a colder heat range .
Unread 07-06-2012, 10:41 AM
I failed to mention in the other linked post; that 8 is better if you live in the city with a lot of stop and go traffic as it disperses heat faster, in turn cooling the head quicker, since most of the time you're just sitting in traffic. If you're only in stop and go traffic for little bit to go riding; more in the country and back roads, or already live away from heavy traffic and lights; then the 6 is a better choice.
