Unread 08-31-2010, 12:09 PM
alfredo alfredo is offline
Default honda CS 95 aņo 1960
i am a new member, I have a honda cs95 benly wanted to know if either the model or only the CS were 125cc
thanks
Unread 09-01-2010, 02:20 AM
They were made but I am not sure which market for, they never came to the UK and I've never heard of them being in the States.
Here is a list of the model designation numbers for all the 125 and 150 twins in the early Benly range.
200 C 90
201 C 95
202 C 92
203 CA92
204 CS92
205 CB92
206 CA95
207 CB95
208 CD92
209 CS95
A lot of parts on the bike will be the same as the C/A/92 and 95s but be carfull when ordering parts as the C95 and CA95 are different motors but both will fit in any of the Benly frames.
Dose your engine number start with CS95E **** and your frame CS95F***?
Unread 09-01-2010, 06:06 AM
Default CS 150 benly
I live in Corrientes Argentina, very few models came here benly either CS 125 or 150, apparently is the only 150 that exists here.
I'll upload photos
thanks
Unread 09-01-2010, 06:35 AM
Hi Alf, I just noted where you are. Take pics of the top crankcase under the carb, that will give us a clue as to how many main bearings the crank has.
Also take pics of either side of the head and the cam cover where it mounts to the frame from the left hand side.
I have a 150 that came from Argentina, I bought it as a CB92 race bike in bits quite a few years ago.
When I unpacked it, it turned out it was a CB95. I'm trying to find out more about Hondas early involvment in Argentina as I belive Argentina Honda was the first Honda race department outside of Japan. This was probably due to the fact that Argentina was the nearest country to Japan that held a round of the FIM Grand Prix series. If you are able to find out anything for me, I would be deeply in your debt.
Regards Sam.
Unread 09-01-2010, 06:38 AM
Alf, also check out the engine and frame numbers.
Unread 11-05-2010, 11:17 AM
Default Datas benly cs 95
HI SAM, TE SERIAL ALWAYS SOMETHING HERE APPEARS THAT ARE LOOKING AND SEE
TE DATA STEP AN ENGINE CHASSIS
C95E-1600958 ENGINE
C95-1400228 CHASSIS
WHEN CAN upload photos
THANKS
Unread 11-05-2010, 11:22 AM
HI SAM VA UNA FOTO DE LA MOTORCICLE
