Unread 09-27-2012, 06:22 AM
1911tex 1911tex is offline
Default Rubber covers for clutch and brake adjusters
These slip over the knurled adjusters at cable end at handlebar.....were they available for the Benlys? If so, where available? I had one only over the clutch lever adjuster on my '63, but was split open and useless.
I also have a Honda CM200 1980 with the covers in great condition. Went to the ebay CM200 parts site and could not find them...they fit perfectly on the Benly.
Only reason I ask is that these rubber covers really clean up the look of and keep grime out those knurled adusters. I looked at early ad photos of the Benlys and could not tell if they came as original equipment.
Unread 09-27-2012, 07:00 AM
I didn't see any rubber covers for the lever-mounted adjusters in the parts manual.
Unread 09-27-2012, 07:16 AM
Here is a picture of the covers I am referencing...ByTheLake, I did not see them in the CA95 manual as well, but one torn-up one was on my CA95:
http://www.hondarestoration.com/fich...m200_model199/
If this does not download properly, the OEM # is 53171-402-700 and it is called a cover handle lever...however, shows for an '80 CM200.
