Unread 03-01-2014, 03:08 AM
marctroy marctroy is offline
Default CA95 seat on CA160?
It appears that the only difference between the CA160 and CA95 seats are the front mounting tabs. If the holes on the CA95 tabs are modified into slots like the CA160's tabs will the CA95 seat work on the CA160?
Unread 03-01-2014, 06:36 PM
The 1964-65 CA95 seats are interchangeable with the 1966-69 CA160 models. The frame seat mounts on the CA160's are upgraded with rubber inserts. The hardware in the mounts, where the seat connects to for both models are the same.
