Custom Fabed Deep Seated Buco L.E.D. Lights
I finally figured out how to recess the bulb socket into a chrome body. This allows a L.E.D. light to be installed in Buco Twinmaster Saddlebags.
Reason: more pic
Reason: more pic
Spokes wrote:I finally figured out how to recess the bulb socket into a chrome body. This allows a L.E.D. light to be installed in Buco Twinmaster Saddlebags.
hey spokes, nice job!!! i'm getting ready to install lights in my buco bags...can I jump the wiring right off the brake light? also do you have a parts list for this project? awesome summer!!!
Thanks, yes, you can jumper your brake light or running lights to the bag lights. Remember that you have to ground the lights in the bags. This is normally done by running a ground wire from the light to the bottom plate that reinforces the bottom clamp.
I don't have a parts list per se, because I use die's for the bulb socket hole in the body and a press to countersink the socket. I also use fixtures for making the bracket that holds the light in the bag as well as a drill press.
So these lights are pretty custom. I only build a few sets per year when I can find chrome light bodies.
2003Drifter
Just finished a set of L.E.D Visored lights. http://www.ebay.com/itm/200734045613?ss ... 1555.l2649
The next set of 4 lights will be done this week.
