Page 2 of 2
Posted: Wed May 22, 2013 1:33 pm
by ByTheLake
rum-rum wrote:i have the same pipes and used aliminum muffler tape wrapped two or three times on the inside two make the gap tighter .works good so far
Sounds like a good idea, thanks.
Posted: Wed May 22, 2013 3:56 pm
by VegeKev
Thanks for the replies :)
I'll also give the tape a try....would certainly be better than the bright orange rubber... :rolleyes:
Its great to have somewhere to throw ideas around :D
Kev.
Posted: Wed May 22, 2013 11:47 pm
by VegeKev
Just a bit info after some more trawling....
Looks like the trumpy guys have a similar situation. It appears that a common fix is to use common bathroom silicone! :eek: ....some use the high temp auto stuff, but the common stuff does the trick. And they reckon getting the exhaust off after application (so long as its cured) is easy too....
Might be worth a try....I'm thinking of slitting the muffler pipe and using an exhaust clamp as an added bit of stabilising mechanical strength against vibration. :rolleyes:
Kev. :)
Posted: Thu May 23, 2013 9:23 am
by Steverinomeiste
Limited vocabulary- what's a trumpy?
S
Posted: Thu May 23, 2013 11:37 am
by Sam Green
Triumph perhaps?
Posted: Thu May 23, 2013 5:27 pm
by VegeKev
Sorry People....yes (as usual ;) ) Sams on the money.
Posted: Mon Jun 17, 2013 9:28 am
by lavs4X4
Nice Job! Well done!
Did you have your tank side covers rechromed or were you able to find a better set?
Posted: Mon Jun 17, 2013 1:08 pm
by ByTheLake
lavs4X4 wrote:Did you have your tank side covers rechromed or were you able to find a better set?
I found that set on eBay. They were in good enough condition to cancel my plans to have them re-plated.
