Unread 10-29-2010, 12:04 PM
mike mike is offline
Default coil
i have a 1966 benly that spark plug wires are bad, can thes be changed and if so how is it done thanks mike
Unread 10-29-2010, 08:22 PM
Open up the bracket ends that secure the plug wires. (both sides) Chip away the hard sealant at the coil body where the plug wires enter the coil. Once the sealant is cleaned off, pull the wires out in a straight line.
Buy 7mm snowmobile spark plug wire. (or any solid core spark plug wire) The snowmobile wire can be found on ebay.
Cut the wires to length. Before inserting the wire back in the coil, apply some clear automotive sealant to the outside of the wire about 1/2" high.
Push in the wire and allow the sealant to cure. Resecure the wires in the bracket. You can use your original spark plug caps or get new ones. You can find new plug caps at www.hondaminitrail.com or ebay.
Unread 01-29-2011, 04:41 PM
djbrett djbrett is offline
always informative Spokes. Let me ask a question though. I just pulled out the old wires and, it appears that, on the coil, the right wire receptacle has a hole in the middle and left one has a wire or something sticking out. Is this right? do I need to trim the casing back and expose the inner spark plug wire to go into the right hole?
Unread 01-29-2011, 05:23 PM
Hmmm. There should be two pins in the base of the coil where the plug wires spear into. If your using 7mm spark plug wire, you won't need to trim. Use a little lube to insert the wire. Wipe clean before sealing.
Unread 01-29-2011, 09:13 PM
I guess that means the pin is missing on the right side. that's no good hopefully i was just wiped out and didn't see right. guess i can plug in the wires and check for a spark.
Unread 01-30-2011, 08:47 PM
yeah, i was just tired. Sorry to waste your time. Got spark!!!! and new wires and caps. Also found out the gas was leaking out my carb overflow due to a worn float jet, or whatever the thing is. slowly but surely.
