Benly has me Bushed
Greetings
I was trying to fit the rear wheel to the Benly and I noticed that it is missing a bush on the left rear item number 13. If someone has some time could they provide the measurements please :) I believe it is 22mm ID . Need the OD and width http://www.cmsnl.com/honda-c92cs92-b...1.html#results Cheers Greg |
ID 22.00mm OD 28.84mm Width:9.46mm
The above measurements are from a CA95 rear hub spacer. I have a spare (the one I measured) if you have the time to wait for delivery. |
Thanks for the help and offer of the part. I will keep in mind. At this stage I will turn one up on the lathe.
regards Greg |
